CT235 5 amp fuse blow
   / CT235 5 amp fuse blow #1
winston1
Super Member
gilmer tx
Bobcat CT235
Had been brush hogging, came home, backed tractor off trailer, started forward and she died. Ignition was dead. After inspecting fuses I found a blown 5amp fuse labeled Operational control unit/switched power relay. Although I know not recommended my seat safety switch is bypassed and has been for years. I replace the fuse, started right up, I backed it up engaging pedal with my hand so I could search for a fuse I had dropped. It idled probably 5 minutes, I then got on the seat, started forward and it died. Same fuse blown, replaced it again, let idle several minutes, got on, went back and forth, then parked it in the shed. Mysterious to me, anyone ever experience anything like this? Not really sure what the switched power relay is, could it be the same as ignition relay?
Found my problem. Seat switch wire had been mashed so much it had a bare place and when I sit of the seat the wire was grounding out.
   / CT235 5 amp fuse blow #3
That was my thinking too. Smashing the jumper. :confused3:
   / CT235 5 amp fuse blow #5
Same issue happened to me. In my case I sat down in the seat hard and it died. Went through a lot of things before I found that fuse and that my seat switch had shorted. So if you tractor dies suddenly this is a good place to start.
2018 Chevrolet Silverado (A55973)
2018 Chevrolet...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
huqvarna trak star 1270 rail demo saw (A56435)
huqvarna trak star...
Dewalt D28499 7/9" Angle Grinder/Sander (A59076)
Dewalt D28499 7/9"...
Brock Meyer 2000S 70'x12' 2000 BPH Grain Dryer (A57148)
Brock Meyer 2000S...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
