bob2299
- Joined
 - Dec 14, 2010
- Messages
 - 67
- Location
 - Canada Northern Ontario
- Tractor
 - Bobcat ct230, 35 hp Massey Furgeson 3Cyl Diesel
Hello I have spent the whole summer building and installing a cab on my CT230, My problem is I have no heat and my temperature gauge does not read temperature when I hook up my heater core,
The heater core is installed on the roof of the cab, so it's higher than the motor, someone told me I may need a auxiliary pump, I had it working a few day's ago, my trouble was it had ( I think) an air lock, I was able to get it to give heat and the temperature gauge was working,
The way I figured it out if the water does not flow true the heater core the temperature will not read on the gauge.
the trouble is I had it working, but the next day, I think it has another air lock, so now i am wandering if i do need a pump to move the anty freeze, or do I just need to try and remove the air lock another time. I am wandering if I will have air lock in this system on a regular basis because it is higher than the motor.
Thank you for your help.
