CT230 backhoe?
/ CT230 backhoe? #41
I am looking at an additional 9" bucket to go along with the 18" that comes standard on it. I think the 9" would come in handy for trenches to run drain pipe or wires or stuff like that. What are your thoughts?
I am also trying to decide if I would use the additional hydraulic thumb. It seems like a nice to have but is it $980worth of nice to have? For those of you that have them, do you use them much? What do you use them for?
If you have sandy or very dry soil a 9" bucket could be useful. If you have clay or wet soil it will likely be clogged with dirt and not empty easily so keep that in mind. You can do trenching etc with the 18" too so it is a pretty expensive add on.
I have the Woods mechanical thumb. I find it moderately useful. It would be very useful if I did not also own a 4n1 and grapple. I tend to just turn the tractor around and grab the stump or rock with the grapple/4n1 as I will need to get the object into the FEL sometime anyway if I am carting it away. I use my mechanical thumb about 5% of the time. Nice to have but not a great bang for the buck.
If I were building a rock wall I would imagine the hydraulic thumb would be real handy but I don't do that professionally so it is hard to justify the limited time savings over a mechanical thumb. You should also be aware that it is really not such a big deal to convert the mechanical thumb to hydraulic. The only part that would be difficult without getting expensive parts from Woods is the foot pedal control. If you can tolerate standard valve controls to operate the thumb then a conversion shouldn't cost more than $300-400 for a hydraulic cylinder, hoses and a simple valve.
/ CT230 backhoe? #42
I don't have one but I saw landscaper used it to pick up rocks that is too big for the bucket while digging and logs too when they were working on my yard... Also used to pick up plants by the root balls then set it to the hole. I wish I can afford one :drool:
/ CT230 backhoe? #43
The thumb is pricey, but get it now if you want it. I agree that the 9" might clog on you pretty easily. I suggest going with a 12". I've dug a lot of trenches with my 18" bucket. But many times I wished I had a narrower bucket to keep the trench small, like when the trench had to be filled with 2" of sand to meet code. That's a lot more sand.
I'd like a 3PH pto trencher that works like a ditch witch. I've been looking for a used one, but they are rare. The few I have seen are hydraulic for skidloaders. Still hard to justify when you already have a backhoe.
/ CT230 backhoe?
$980 does seem a little pricey but that is installed and like you said if I think I might use it then I should probably get it now as I doubt I would get it later.
My soil is pretty sandy and the 9" bucket was quoted to me for $350 so I didn't think that was too bad. But would I really use it that much?
A grapple would be nice. I would eventually like to get one myself.
/ CT230 backhoe? #45
/laugh
I can see some people here are H. Rider Haggard fans.
/ CT230 backhoe? #46
I think I just about have the wife convinced to buy one even thought she still doesn't think we need one. But, she has agreed there will be no divorce over it if I do.
Did you typo "hydraulic" thumb when you meant "mechanical" thumb? I bought my Woods BH90-X a year ago with a hyd thumb and they at that time didn't offer a hyd thumb on a BH80-X, just a mechanical thumb-koodoos if Woods has since designed a hyd thumb for the BH80-X.
/ CT230 backhoe?
No, I meant hydraulic. It must be an option now, it did say just added.
/ CT230 backhoe? #48
Only out of curiosity I emailed Woods last week and got the answer today-they do now offer a hydraulic thumb for the BH80-X and a kit to convert if you already have the mechanical thumb to hydraulic. ENJOY!
/ CT230 backhoe? #49
Victor mentions being able to drag his tractor around with his backhoe. This is a capability that many people don't realize is important. Depending on your use environment, you may occasionally (or frequently?) bury your tractor; especially in soft sand, mud, or swampy ground. Knowing how to use the backhoe to walk yourself out of the hole can save you a very expensive wrecker tow, or possible damage to your tractor.
/ CT230 backhoe? #50
Maybe it's just me and I don't know how to do it, but I've had no success trying to walk my tractor. Of course, my bucket is always on the ground (usually with the toothbar biting into the ground) and the park brake is set hard. I also have filled rear tires. I've tried from the backhoe set to push the tractor forward (with loader raised) with the backhoe and don't have a great deal of success. I've always had the park brake set and it in 4WD. Haven't tried it from 2WD. Maybe that makes a difference. I can pick up the rear end and swing it sideways, but I haven't been able to push it, nor pull it for that matter. Is the 4WD with the brake set stopping me?
/ CT230 backhoe? #51
With it being in 4wd and the rear brakes set, you, through the gearing and drive connections, have also locked the front wheels. I doubt if mine could move the tractor this way. When I have had to move mine with the bh, I have the front bucket on the ground lifting the front tires ever so slightly off the ground or out of the holes and with the cutting edge up a little so the bucket works like a ski. The bucket will also keep you from tipping sideways when the back end is only on the bh bucket. Also, the brakes are off.
I do this only if I get it stuck and it's the only way to get it out. This shouldn't be used as a way just to move the tractor. A dedicated front loader/backhoe machine is built much heavier to take these forces compared to how our tractors are built.
/ CT230 backhoe? #52
With the toothbar biting into the ground it would be pretty hard to push the tractor in the forward direction. The side stabilizers will also resist and are potentially damaged with this sort of manuver. The few times I've done it I've raised the stabilizers out of the ground (and I don't have a toothbar). The brakes won't cause any trouble.
/ CT230 backhoe? #53
Note I said with loader raised, and of course, the outriggers are up. Will just have to experiment with 2 WD, and maybe try riding on the bucket in lieu of that. I just don't like to pick up the tractor completely on the implements. It almost has to be the combo of 4WD and the park brake because the backhoe should easily push/pull a free-wheeling tractor. Anyway, I don't try the backhoe moving thing much. But sometimes I just need a foot or so fore or aft.
/ CT230 backhoe? #54
Sorry I missed that. However, I find my DK can be pushed/pulled around inadvertently even with brakes, 4wd, loader down with edge in ground. I don't try to move it intentionally like that but I end up scooting around especially when digging at roots or big rocks. Not so much an issue with just digging soil.
/ CT230 backhoe? #55
You probably don't want to do this if you have a 3-pt BH attached; it won't take the abuse. Frame-mount is a different story.
And yes, you can easily damage your equipment this way. Take it slow and easy, and don't put lateral pressure on the FEL if you're using it as a skid.
/ CT230 backhoe? #56
Bringing a thread from the dead!!!
I have a Bobcat CT335, by reading several posts, I guess my 8tb Hoe was Built by Rhino, Is this Correct?
I'm Looking for a 9" bucket for it, any Idea as to what one would cost and where?
A couple of Bobcat dealers have priced them in the range from $390 to $446 plus shipping, can I get a Rhino cheaper than a Bobcat?
/ CT230 backhoe? #58
I have a Rhino 85 backhoe.
I use Kioti 2385 backhoe buckets.(perfect fit)
Its been a few years but my Kioti 12" bucket was around $250 and my 36" Kioti bucket was around $450
/ CT230 backhoe? #59
I got a quote from Wallace about a 2 years ago for a 12" Rhino bucket. As I recall it was about $450 to $500.
/ CT230 backhoe? #60
The price I gave you was on a Rhino bucket.
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
