CT225 maintenance log (printable)
/ CT225 maintenance log (printable) #1
rus_geek
Poniatowski, WI
Bobcat CT225
Just put this together so I have a checklist I can actually check off, including dates and (small) notes for each item if needed. Figured I'd post it up here, since it might be helpful to someone else.
-rus-
  • CT225_maint_log.xls.pdf
/ CT225 maintenance log (printable) #3
Thanks cleaner looking and nicer than the notebook I had started
/ CT225 maintenance log (printable) #4
This is the maintenance log I made for my CT230. I scanned the maintenance schedule from the manual and added some servicing items at the top. I just check off the appropriate items on the appropriate maint cycle. Simple but it works well.
  • CT-230 Maintenance Sheet.pdf
/ CT225 maintenance log (printable) #5
Thank you for the Maintenance log. Very simple and well thought out. You the man!
/ CT225 maintenance log (printable) #6
I know this is an old thread, but I use these all the time and wanted to bump them to the first page for some of the new guys to see:thumbsup: The only thing that I change is to grease the fittings every 8 hours of use. (always have always will)
/ CT225 maintenance log (printable) #7
It is an old thread but a good one I had not seen before. Thanks and I will use it for my 230.
/ CT225 maintenance log (printable) #8
Sorry I know this is an old post but the maintenance sheet is great, hope you don't mind. Kev
/ CT225 maintenance log (printable) #9
Is this checklist pretty universal? Wouldn't mind using it for my Deere 1026R.
/ CT225 maintenance log (printable) #10
so the shaded ones are not required at that interval?
