CT2025 rotary cutter
   / CT2025 rotary cutter #1
brierpath
Bobcat CT2025
Cut about 3.5 acres this weekend with a County Line 4 ft cutter. Field was overgrown grass and weeds, about 2ft tall. 2025 handled it well. About halfway through, noticed the temp gauge above halfway. Stopped to check things and found the air intakes on the hood were all clogged with fluff. Brushed it all away and checked the radiator filter screen. It was clean. It appears the air intakes on the hood are small enough holes that they stopped that stuff before it got to the screen over the radiator. Started back up and gauge went below mid point in a few seconds.
Only gripe with the 2025 so far is that I cannot see the parking brake indicator well in sunlight. I can attest that you can cut with the brake engaged(idiot).
   / CT2025 rotary cutter #2
Well since you admitted it, we can be idiots together! I drug a 40 foot spruce tree clamped in the backhoe about 300' down the driveway before I realized the parking brake was on.
golf cart (A55787)
golf cart (A55787)
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
2013 PETERBILT 367 TRI-DRIVE WET KIT (A55745)
2013 PETERBILT 367...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
ALLMAND LIGHT TOWER (INOPERABLE) (A55745)
ALLMAND LIGHT...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
