CT2025 rotary cutter
   / CT2025 rotary cutter #1
brierpath
Bobcat CT2025
Cut about 3.5 acres this weekend with a County Line 4 ft cutter. Field was overgrown grass and weeds, about 2ft tall. 2025 handled it well. About halfway through, noticed the temp gauge above halfway. Stopped to check things and found the air intakes on the hood were all clogged with fluff. Brushed it all away and checked the radiator filter screen. It was clean. It appears the air intakes on the hood are small enough holes that they stopped that stuff before it got to the screen over the radiator. Started back up and gauge went below mid point in a few seconds.
Only gripe with the 2025 so far is that I cannot see the parking brake indicator well in sunlight. I can attest that you can cut with the brake engaged(idiot).
   / CT2025 rotary cutter #2
Well since you admitted it, we can be idiots together! I drug a 40 foot spruce tree clamped in the backhoe about 300' down the driveway before I realized the parking brake was on.
2013 Ford Explorer AWD SUV (A50324)
2013 Ford Explorer...
2016 Caterpillar D6N LGP Crawler Dozer (A50860)
2016 Caterpillar...
2006 GMC 4500 Bucket Truck with Altec AT200 - 34FT Working Height (A51039)
2006 GMC 4500...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A51039)
2024 BCL...
2015 Ford Explorer SUV (A48082)
2015 Ford Explorer...
1049 (A50459)
1049 (A50459)
