CT122 losing power
/ CT122 losing power #1
No Guns Here
Bobcat CT122
I have a CT122 (not sure of the year). It's been a champ since I got it a couple of years ago. Last week it started randomly losing rpms/power. With load, without load, in gear, out of gear. I can set the throttle at say 2500rpm and after a minute or three it will start backing down. Sometimes it will run back up, sometimes it will just drop RPM's until it dies. Additionally, the tach used to stay rock steady wherever I set it. Now, when idling it bounces around a bit.
I've refilled with new diesel and changed the fuel filter. The air filter is clean and she is full of oil. The battery tests fine and strong. I see no fuel leaks in the engine bay.
What should I look at? I'm not really a mechanic but between google, me, my son and my FIL we usually figure stuff out.
/ CT122 losing power #2
Since you say the RPMs and power come back, fuel delivery fluctuation is the most likely cause, Are there any additional screens/fitters at the fuel tank outlet on that model? One of the benefits of many older models is gravity feed to the fuel filter. You can probably confirm there's a good steady flow of fuel into the main fuel filter by simply taking it apart again and watching fuel drain through for a little bit. If you don't get a steady flow you can chase the line back to the tank and check for obstructions. There may even be junk in the tank that affects outflow.
/ CT122 losing power #3
Sounds like exhaust blockage or fuel delivery to me.
/ CT122 losing power #4
Tman has a good point about exhaust restriction being a possibility too. On my larger model there is a plug in the bottom of the muffler that I’m supposed to remove periodically to let any accumulated soot blow out of. The plug is removed then the engine gets started and run at working speed for a bit. I’ve never had any real noticeable amount come out personally. But it definitely is another quick check you could perform. If it doesn’t have a plug you could also just pull the muffler and check for obstruction the old fashioned way too.
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
2020 VOLVO VNL760 SLEEPER TRUCK (A59914)
2020 VOLVO VNL760...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
Volvo SD100D Single Drum Vibratory Soil Compactor (A61572)
Volvo SD100D...
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
