Ct 450 sst or not
   / Ct 450 sst or not #1
articatsopro
New England
Came real close to pulling the triiger on a CT235 but I can afford a CT 450 for a very good price with cab but am wondering about the sst. It will be use mainly for loading and mowing work/some snow removal, The thing that puzzles me is Kioti does not offer or at least I don't see a equivalent to the sst.. Whats your guys opinions on the sst. My family owns a heavy equipment company so this is primarily for my house and brush hogging around the shop and some land I bought.Ive been around tractors for a while just not the new ones. Thanks
   / Ct 450 sst or not #2
Were waiting on the boat to dock!!!!:rolleyes:
   / Ct 450 sst or not #4
Usually the shuttle shift is cheaper....
   / Ct 450 sst or not
Endned up going with a 440 cab there was one locally got a better price should be here next week (friday) 2 rear remotes 1 front 96 blade filled tires finsh mower brush hog tiller forks
   / Ct 450 sst or not #6
Not 100% positive but I think you'll find that the SST is NOT available in the cabbed models. I know that because I specifically wanted a shuttle shift transmission in either the CT445 or CT450 which I am looking at and the dealer advised that the SST (as with the Kubota models and apparently the KIOTI models) is not an option if you get the enclosed cab. For some reason, most manufactures aren't making the less expensive trans available in the upgraded cabs.
I have been using a shuttle shift for years in my Kubotas and really like it. You loose power (approximately 3-4 hp) when you run the same tractor with the HST trans vice the SST.
Good luck and if you find out different, please let me know.
   / Ct 450 sst or not #7
Kioti will have theirs very shortly as a matter in fact there was one at Kioti when we had our national sales meeting last week.
Eaton PRS0100001 145psi Rotary Screw Air Compressor (A56857)
Eaton PRS0100001...
2016 PETERBILT 579 (A58214)
2016 PETERBILT 579...
New Holland 650 Hay Baler (A53317)
New Holland 650...
LOT: Fill-Rite Pump, Fuel Transfer Tank, Tool Box (A59076)
LOT: Fill-Rite...
VERMEER PD10 PILE DRIVER (A52709)
VERMEER PD10 PILE...
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
