Mowing CT 335 Wont Start
   / CT 335 Wont Start #11
I did a year or so ago
Luckily I had ordered some paste ( don't know the name of it off hand) James recommended and used it when I replaced it
I am hoping that this one lasts longer
Does anyone else know if Kioti uses the same chinsey cable that Bobcat does?
I look in almost every auto store for something I can use to replace it but so far no avail.......
Just remove the lug on the end of the cable and solder on a new lug. Takes no skill. You need lug,flux solder and a torch. Getting old lug off is 90% of the job. You can then just add a battery terminal with a bolt on it if you lug is still good.
   / CT 335 Wont Start #12
The problem is:
your hat.
If you didn't wear the hat, this wouldn't have happened. I hope you learned your lesson. :)
I never wear a hat except in the coldest wettest part of winter.
   / CT 335 Wont Start #13
Did the OP ever get it started and what was the cause? - just curious.
   / CT 335 Wont Start #14
Did the OP ever get it started ad what was the cause? - just curious.
Haven't heard a peep from the OP. I hope he responds. It's frustrating when there's no
response from an OP as to whether a problem has been resolved or not.
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
2012 PJ Trailers PJFS25 25ft T/A Gooseneck Flatbed Equipment Trailer (A55973)
2012 PJ Trailers...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2018 Ford F-150...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
