Snow CT 335 HooAh!
   / CT 335 HooAh! #1
laen64
Ashford Alabama
Bobcat CT335 SST;FERRIS IS 1500Z 25hp 52"
I finally have the permission to PULL the trigger. I should take delivery prior to the week end. I did get the deluxe seat and 1 remote.
It's dressed up with FEL/ BB Sun shade.
Can't wait I have some lingering chores to do.
:thumbsup:
   / CT 335 HooAh! #4
If you have not already planned on doing so I would recommend filling the back tires. That 8TL loader with a bucket full of dirt will lift the tail right up. It is quite an akward feeing.
   / CT 335 HooAh! #5
Sorry, but I highly disagree.
Do NOT fill the tires. Just get a box blade (which everyone needs anyway) and keep it attached when using the FEL. Takes 2 minutes to install/remove. Once you load the tires, you are stuck with loaded tires and the tractor is pretty much done as a grass mower on a nice lawn. I have picked up overflowing loads with my FEL and never once had an issue of the rear tires coming up with the box blade mounted.
   / CT 335 HooAh!
yes Sir the plan was to fill the tires. However I see other replies that differ. I think I'll talk with the dealer and see if I can put this off and do some of the chores with the BoxBlade mounted.
   / CT 335 HooAh! #7
If your working in tight spaces were the extra length of an attachement can be a issue; weighted tires is still a good alternative for ballast. I would suggest reading your operators manual though to make sure you understand what type of tire filling is exceptable without voiding your warranty.
   / CT 335 HooAh! #8
Unless the machine is a dedicated grass mower (in which case you may want a different machine to start up with), filling the tires helps tremendously with the safety factor if you are picking up loads and moving them over ground that is is even slightly un-level. I have loaded rears and keep an 77" Industrial Gannon Box blade out back (1090 lbs) and still can raise a rear tire off the ground with my CT230 while creeping along (slower than walking speed) with a heavy load. I'd rather buy new tires and rims (from rust / rot) than deal with the aftermath of a rolled machine should I live to tell about it. In fact if my machine use increases, I may need to even look into making the stance wider and / or adding rear wheel weights.
Steve
   / CT 335 HooAh! #9
Load the rear tires way to many benifits as many have explained. I mow with my ct450 on the nicest lawns, I use a 72 rear finish mower but I do take off the loader completely and always leave lawns lookin good...
   / CT 335 HooAh!
I Pulled the Trigger today and will take delivery on Monday HooRah!
I did get the tires filled, the dealer had it completed before I arrived. So my new toy is the CT335 SST with FEL/BoxBlade Deluxe seat 1 rear remote. Tires 1 size larger R-4's than normal issue.
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
Payment Terms (MUST READ) (A50775)
Payment Terms...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2003 - 1890/1910 Air Seeder and Air Cart (A51039)
2003 - 1890/1910...
UNUSED MOWERKING QUICK ATTACH BOX BROOM (A51244)
UNUSED MOWERKING...
