Loader CT 235 Power Beyond Picture?
   / CT 235 Power Beyond Picture? #11
Correct. Install the kit Winston1 posted with the AUX kit thumbnail.Bobcat PT#7150492 Make up and run your plumbing as described. Yes its a nice set up that don't mess with any of the other hyd functions. Do you have the Detachable bucket on you loader?
   / CT 235 Power Beyond Picture? #12
I can't remember the relationship of the loader joystick and the rear remote valve, but on my Kioti DD35se it is pretty convient to operate. I did extend the length of the valve stick to make it more so.
Yes, the Bucket is a "Bobtach" setup with 2 levers to disconnect. The parts description for the #7150492 Auxiliary Kit list part 25: 6697824 Valve, Control detented. So it looks like the Detent is a part of the kit. Thanks to you, Winston and everyone else for all the assistance. I'm going back to the dealer this week and ordering the Auxiliary Kit. I'll keep you all posted as I install it.
Mike
Yes, the Remote lever and the Loader "joystick" are right next to each other. That's a good idea about extending the length I'll keep that in mind. Thanks for the reply.
Mike
   / CT 235 Power Beyond Picture? #16
The Kioiti kit for the CK 35 also fits, and has a float feature on the second remote, while the bobcat kits do not. Do a search under my user name as I installed a dual set and ran remotes to the front. Pictures included.
   / CT 235 Power Beyond Picture? #17
Installation of the AUX valve(3rd function) is easy.I can install the kit in less than an hour. It stacks onto the 3point valve or #1 AUX valve if you have it. Definitely remove the seat. This gives you great access. Don't forget to unplug the seat switch. I have installed lots of these valves and hoses to the front loader frame for customers. Have the 2 hoses split with couplers so you can remove loader if nessary.Locate these couplers approximately under R foot rest. Fab a L shaped mounting bracket for a second set of FF couplers if you have an SSL type mount for your bucket. The bracket can be mounted on the cover plate that protects the steel lines on the front loader cross member. This set up gives you AUX hyds out front and the ability to use other attachments. Get the detent kit for the valve. I thinks its only about $50. this gives you continuous flow option both front or back. You may be able to modify the valve lever to make it more user friendly with the FEL valve lever.
I need to get hoses made to run to the front, I have the bobcat 7150492 rear kit, what couplers plug into this?
   / CT 235 Power Beyond Picture? #18
Give Brian at Fit Rite Hydraulics a call. He set me up with my hoses to the front and will have all the measurements I used. I also posted pictures of my install if that helps. Search my user name.
DOOSAN G25 GENERATOR (A58216)
DOOSAN G25...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
Honda UTV (A56859)
Honda UTV (A56859)
CHEVROLET C-30 CAB & CHASSIE (A52708)
CHEVROLET C-30 CAB...
Tool King 12-Ton Hydraulic Pipe Bender (A59076)
Tool King 12-Ton...
2016 INTERNATIONAL 4300 SBA FLAT TOP ROAD TRACTOR (A58375)
2016 INTERNATIONAL...
