Loader CT 235 Loader Arms only going half way up.
   / CT 235 Loader Arms only going half way up. #1
OH10
Tallmadge, Ohio
Bobcat CT235
I was out back clearing brush and as I brought the CT 235 back up by the house I discovered the loader arms will only raise half way up. The hydraulic fluid level is full and there are no leaks, I have an EA wicked single gate grapple attached and it is working fine, so does the tilt or curl function. I checked the loader cylinders and they both look ok. I don't know how else I can trouble shoot the problem. Any ideas?
Mike OH10
Belay that last. I did find a leak just now. On one of the hose fittings by the main valve block,
   / CT 235 Loader Arms only going half way up. #2
One of your loader hose quick disconnects is unlatched by a branch, so the oil from the cylinder can not return to the tractor. Unhook and rehook them.
Thanks for the reply. I believe you are absolutely right.
   / CT 235 Loader Arms only going half way up. #4
well done
1049 (A50459)
1049 (A50459)
2019 CATERPILLAR 308 CR EXCAVATOR (A50458)
2019 CATERPILLAR...
2022 Ram Bighorn 2500 4X4 (A51039)
2022 Ram Bighorn...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2018 CATERPILLAR 249D TRACKED SKID (A51222)
2018 CATERPILLAR...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
