Loader CT 235 Loader Arms only going half way up.
   / CT 235 Loader Arms only going half way up. #1
OH10
Member
Tallmadge, Ohio
Bobcat CT235
I was out back clearing brush and as I brought the CT 235 back up by the house I discovered the loader arms will only raise half way up. The hydraulic fluid level is full and there are no leaks, I have an EA wicked single gate grapple attached and it is working fine, so does the tilt or curl function. I checked the loader cylinders and they both look ok. I don't know how else I can trouble shoot the problem. Any ideas?
Mike OH10
Belay that last. I did find a leak just now. On one of the hose fittings by the main valve block,
   / CT 235 Loader Arms only going half way up. #2
One of your loader hose quick disconnects is unlatched by a branch, so the oil from the cylinder can not return to the tractor. Unhook and rehook them.
Thanks for the reply. I believe you are absolutely right.
   / CT 235 Loader Arms only going half way up. #4
well done
2014 DRAGON 130 BBL STEEL VACUUM TRAILER (A55745)
2014 DRAGON 130...
CATERPILLAR CP44 PADFOOT ROLLER (A52707)
CATERPILLAR CP44...
UNUSED Yellow Outdoor Patio Fabric Screen (A53117)
UNUSED Yellow...
2002 Chevrolet S10 Pickup Truck (A55852)
2002 Chevrolet S10...
John Deere 7410 (A53317)
John Deere 7410...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
