Tractor Sizing ct 225 or ct 230?
   / ct 225 or ct 230? #11
I also have the CT230, with a front snow blower, 6 feet wide, it work good and I get 24 inch of snow here in Northern Ontario. the only draw back is you have to remove the bucket. $1000.00 difference, are you paying cash because if you are making payment what is the difference on a 5yr payment for $1000.00 more, I am only asking because when I bought mine they had a 5yr zero interest payment plan.
   / ct 225 or ct 230?
They gave me a cash price instead of the % interest deal. Sounds like the ct 230 would be the better investment in the long run.
   / ct 225 or ct 230? #13
With the HST drive, ground speed can be adjusted to compensate for 3 less hp. Is it worth $1000 to go a bit faster when tilling or blowing snow. Power shouldn't be a factor most of the time.
Loren
   / ct 225 or ct 230? #14
I would suggest that you look seriously at the Bobcat CT 235. It gives you an extra 5 hp over the 230. You can never have too much HP!
   / ct 225 or ct 230? #15
Get the 230 or the 235 if you can afford it.
Horse power matters when it comes to responsiveness of the hydraulics as well as the pushing/pulling capacity of the tractor.
The difference between a CT225 and a CT235 running a brush hog through the pucker brush is very noticeable. Ditto running a PTO driven wood chipper.
   / ct 225 or ct 230? #16
I have had the 230 for a little over 2 years and am very happy with it. I'm primarily a hobby farmer, but use the tractor as my primary snow mover. I have a 64" rear snow blower and have no problems even with that wet slushy stuff the town plow leaves at the end of the driveway. Good luck with your decision!
   / ct 225 or ct 230? #17
Just got rid of a CT225 with the 27HP engine. I have to say I was very disappointed. I bought it because I got in on the early deal with the free loader and a $3000 rebate. I have hills and I can honestly say unless your ground is flat, I would not have one of these with less than the 35HP engine. I could not come up my back hillside with the front end loader on without going to low range. I could not brush cut on any of the hills except in low range and I bogged her down bad even them. My old Kioti LK3054 would go up those same hills with the brush cutter and a loader in 5th gear and I could accelerate if I wanted to. There is no comparison. With the hydro go for the HP. Also, the key on these models is in a horrible place. Good luck with the knees. Check your local dealer, the one in Nashville didn't seem to care about tractor customers.......other than that, I will be looking for a good used LK 3054
   / ct 225 or ct 230? #18
I have a CT235 and I have hills, and I can go up them in second, and sometimes even third if I have enough of a head of steam built up
:confused2:
   / ct 225 or ct 230? #19
:confused2:
That's why I said get a CT235 over the other 2. I don't see 3 HP making a difference but 8 should. I could put my loader against a tree in the field on dry hard dirt and wide open in low, barely openly the hydro pedal, I could stall the engine before I could spin a tire. Dealer brought another out to my place and he couldn't climb the hill or spin a tire either.....last I ever heard from the dealer.
So, if you really want to work get the 35 HP or get a gear tranny. That is my plan.
   / ct 225 or ct 230? #20
I have no power problems with my CT230. I have spun out and dug many holes with the tires. I've lifted stuff that amazed me. I've pulled a hydro service truck out of the ditch with wet slushy snow on the ground.
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2019 John Deer 3038E 4 x 4 Tractor w/300 E Loader, S/N 1LV3038EJKK126097, Diesel Engine, Joystick (A59076)
2019 John Deer...
Evercraft 3-1/2 Ton Floor Jack, 12-Ton Bottle Jack (A59076)
Evercraft 3-1/2...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
TANK SEEDER (A58214)
