CS2510 No power in reverse
   / CS2510 No power in reverse #1
dougdou
South Carolina
Kioti CS 2510
My CS 2510 with 42.0 hrs has recently lost power in reverse. Hi or Low range doesn't matter. The transmission is topped off. Works well in forward drives, the reverse pedal almost seems like their isn't enough throw to fully engage reverse. Is there an adjustment for the reverse pedal? Any ideas?
   / CS2510 No power in reverse #2
First, check all of the linkages under the floorboards going back to the tranny. There may be a loose pin or bolt, or maybe something got bent. Did it happen suddenly or has it been gradual?
Yes, they can be adjusted, but with the small number of hours, it shouldn’t have to be adjusted, unless something is loose. The instructions for the adjustment should be in the owner’s manual.
It was more gradual, I noticed that I wasn't able to push the box blade, and then today I could hardly get it to get out of it's own way. It was getting dark when I was looking at the linkages. I will check it in the daylight to see if I can see anything. The owners manual is very limited when it comes to anything but normal servicing. May have to resort to taking it to the dealership since it is still under warranty.
2011 Ford Transit Connect XLT Cargo Van (A50323)
2011 Ford Transit...
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
2007 JLG SkyTrak 10042 10,000lb 4x4 Rough Terrain Telehandler (A50322)
2007 JLG SkyTrak...
John Deere 4640 Tractor (A50514)
John Deere 4640...
2012 Chevrolet Cruze Sedan (A50324)
2012 Chevrolet...
CFG Industrial STSD10 Grain Drill (A50121)
CFG Industrial...
