CS2220 Kerrr..klunk; beware
   / CS2220 Kerrr..klunk; beware #1
Coyote_CS2220
Bronze Member
BC
2023 Kioti CS2220, Yale GLP050TG, Husqavarna Z242F, Yamaha XT250, 2017 Desert Point Kennels GSP from Yuma AZ
At 161 hours on this 2023 unit and today while moving a load of marble I felt a small Kerrr...klunk when going over a small bump and when shifting from forward to reverse on the HST.
At first I thought it was the new ballast on my 3pt hitch shifting left-right, but a hand on the ballast soon confirmed that was not it.
When I was finished work I parked it, pulled out the floor jack and checked the FEL frame bolts, axle bolts and frame bolts.
Sure enough some were loose:
1) the two 17mm bolts holding the front axle to the frame right in front of the oil pan.
2) left hand side FEL frame bolts.
3) right hand side frame bolts behind the rear tire.
I pull both rear tires and check all of the rear frame bolts and the LH side was good. Same with the RH FEL frame bolts.
???Must have been different people or impact guns putting things together.
A little locktite and a torque wrench quieted things down.
Just a heads up if you sense a Kerr...Klunk on a bump or when shifting from forward to reverse with a load on the FEL.
   / CS2220 Kerrr..klunk; beware #2
I make a point to check the FEL mounting bolts and my wheel torque at least 1-2 times a month if it's getting heavy use.
I'll have to check the axle bolts on mine, not sure I ever have.
   / CS2220 Kerrr..klunk; beware #3
On my unit, i tighten everything a few months after buying tractor. They have never loosened up again….i check regularly all the time.
except for those pesky bolts that hold the pivot pin/grease zerk fittings on loader. Those bolts always loosen up. But there not strategically significant for safe loader work. Even if missing, pin cant fall out due to snap ring securing pin.
Payment Terms (MUST READ) (A50775)
Payment Terms...
Massey Ferguson 65 Tractor (A50514)
Massey Ferguson 65...
2023 CATERPILLAR 279D3 SKID STEER (A51242)
2023 CATERPILLAR...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
