CS2210 flasher relay
/ CS2210 flasher relay #1
jgruninger
2021 CS2210
I replaced one of the flasher lights on my Kioti CS2210 as it got broken recently. A little while later they wouldn't shut off, even with the switch off and the key out. I called the dealer who said it was probably a bad relay. I pulled the fuse (which also operates the horn) to stop it until I can try and replace the relay. Does anyone know where the relay for the flashers is located on this tractor? Thanks
/ CS2210 flasher relay #2
It should show you in the owners manual. Someone should be along with better knowledge of the specific tractor.
