CS 2410 Cab Wiring Diagram
   / CS 2410 Cab Wiring Diagram #1
jabelding
Maine
2014 Kioti CK35 2015 CS2410
I Lost all power to my CS 2410 factory cab today looks like it is probably a relay up in the cab as there are only 3 wires that go to it: Red +12 power, Black ground, and a Red/white for ignition on that I assume activates a relay in the headliner to power up the cab. The Large 20amp fuse in the power feed line is good and the ground looks fine. Does anyone happen to have a wiring diagram for the CS cab? TIA
   / CS 2410 Cab Wiring Diagram #2
Does the cab have its own model number that you can google?
I figured out that my main key switch is not getting power to the relay to turn the cab on, which is also affecting the rpm gauge and bat charging. I sprayed it full of silicone Wd40, worked it back and forth a few times, and it came out of it. I will probably need to replace the switch in spring. It will be fun to get the dash apart with the cab on the tractor.
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2015 Chevrolet Silverado 2500 HD Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
Redirective Crash Cushion Guardrail (A55852)
Redirective Crash...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2020 Caterpillar...
2021 Chevrolet Tahoe SUV (A55853)
2021 Chevrolet...
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55851)
2012 Big Tex...
