Crushed JD 1070 fuel tank
   / Crushed JD 1070 fuel tank #1
irl3r
JD 870
i recently bought a jd1070 which runs great. by fuel tank somehow get partially crushed.
i’m looking for ideas to repair the tank
i appreciate sound advice
thank you very much!
   / Crushed JD 1070 fuel tank #2
Nice tractor!! I used to have one and really liked it.
If you are trying to repair we would need to see some photos to assess the damage and see if it is repairable.
If you want to replace, then a quick search found this:
   / Crushed JD 1070 fuel tank #3
Crushed & torn, or just imploded from a bad vacuum break ? Put a Schraeder valve in the cap and blow it up with regulated air pressure a few psi increase at a time. If you are worrying about blowing up your place, it's diesel. It would take more pressure to burst it than you have compressor for. Filling it partially with water will also relieve your anxiety, but now you have water in a fuel tank. Clamp off the drain line before the tank filter. The bowl is plastic.
   / Crushed JD 1070 fuel tank #4
When inflating,, fill the tank as much as possible with water first.
Water stores WAY less energy as compared to air.
No boom with water, it just leaks out.
Compressed air gets CRAZY amounts of energy, even at a few PSI.
14ft Bi-Parting Iron Gate (Cow Design) (A51573)
14ft Bi-Parting...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53472)
Ditch Witch 6510A...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
