Crushed JD 1070 fuel tank
   / Crushed JD 1070 fuel tank #1
irl3r
JD 870
i recently bought a jd1070 which runs great. by fuel tank somehow get partially crushed.
i’m looking for ideas to repair the tank
i appreciate sound advice
thank you very much!
   / Crushed JD 1070 fuel tank #2
Nice tractor!! I used to have one and really liked it.
If you are trying to repair we would need to see some photos to assess the damage and see if it is repairable.
If you want to replace, then a quick search found this:
   / Crushed JD 1070 fuel tank #3
Crushed & torn, or just imploded from a bad vacuum break ? Put a Schraeder valve in the cap and blow it up with regulated air pressure a few psi increase at a time. If you are worrying about blowing up your place, it's diesel. It would take more pressure to burst it than you have compressor for. Filling it partially with water will also relieve your anxiety, but now you have water in a fuel tank. Clamp off the drain line before the tank filter. The bowl is plastic.
   / Crushed JD 1070 fuel tank #4
When inflating,, fill the tank as much as possible with water first.
Water stores WAY less energy as compared to air.
No boom with water, it just leaks out.
Compressed air gets CRAZY amounts of energy, even at a few PSI.
2014 INTERNATIONAL PROSTAR (A50854)
2014 INTERNATIONAL...
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
1997 John Deere 690 Elc Excavator (A50514)
1997 John Deere...
LINDE H80D FORKLIFT (A50854)
LINDE H80D...
2007 STERLING TRUCK ASPHALT DISTRIBUTOR (A50854)
2007 STERLING...
