Crush Washers
/ Crush Washers #1
kbone1
St.Augustine, Florida
JM 354
Need some help,
I read an earlier post where someone listed a type of crush washer they used to seal the FEL hose connections that were better than the China supplied ones. The washer looked kind-of like a flat washer with a rubber O-ring mounted inside it. They stated that they were a one time use type of washer and somewhat expensive. Can anyone guide
me in the right direction?
Thank you,
kbone1
/ Crush Washers #2
We have them in stock. just measure the diameter the ID of the washer needs to be to work and email with the quantity you need and we can get you a price, I think they are about a buck or so each.
sales@artrac.com
/ Crush Washers #3
I found some at pep boys, Back in the area where they have oil pan drain plugs etc. they have metal washers with a "o"ring in it. They also have a good selection of drain plugs.
AKS ALASKA STRUCTURES PORTABLE TENT (A63276)
AKS ALASKA...
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
2021 Bobcat UV34 4x4 Gas Utility Cart (A64553)
2021 Bobcat UV34...
2018 SolarTech Silent Messenger Towable Solar Message Board (A64553)
2018 SolarTech...
1980 19ft Sailboat w/ 2018 Continental Trailer S/A Boat Trailer (A64557)
1980 19ft Sailboat...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A67148)
2019 FREIGHTLINER...
