Crush Washers
   / Crush Washers #1
kbone1
St.Augustine, Florida
JM 354
Need some help,
I read an earlier post where someone listed a type of crush washer they used to seal the FEL hose connections that were better than the China supplied ones. The washer looked kind-of like a flat washer with a rubber O-ring mounted inside it. They stated that they were a one time use type of washer and somewhat expensive. Can anyone guide
me in the right direction?
Thank you,
kbone1
   / Crush Washers #2
We have them in stock. just measure the diameter the ID of the washer needs to be to work and email with the quantity you need and we can get you a price, I think they are about a buck or so each.
sales@artrac.com
   / Crush Washers #3
I found some at pep boys, Back in the area where they have oil pan drain plugs etc. they have metal washers with a "o"ring in it. They also have a good selection of drain plugs.
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
2014 Morooka MST1500 Crawler Carrier (A52384)
2014 Morooka...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
DoD 88-20041 12.5kVA Brushless Diesel Generator (A51691)
DoD 88-20041...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
