Cruse control on HST
   / Cruse control on HST #1
Hoffie
Southcentral Pa
Kiota CK25
Does anyone use it? When & why? On by CK25 it does not work, that is it gradually slows down and stops.
   / Cruse control on HST #2
I don't have the HST but I remember a post awhile back of someone having the same issue on a 25/30 and it came to getting under the "dash" and tightening the nut(s) on the control lever to put more "tension" on the lever so as not to allow it to back off on it's own when engaged (same as the throttle control on the gear drive). I had to back mine off on my gear drive, which was a pain in the butt to get to! Hope this helps ya.
   / Cruse control on HST #3
I rarely use mine, but when I do it is great. My sister has a house 1 mile down the road (paved) and when she needs work done, like fixing a washed out driveway, I put it in 2wd and high, set the rpms at 2800 and set the cruise at full pedal. It really takes the strain off the ankle. I like it but could live without it.
I'm not sure it's worth messing with.
   / Cruse control on HST #5
I use mine all the time, mowing, going down the road,etc.
   / Cruse control on HST #6
ditto my ck25 does the same thing,i would like to use it when im mowing,so im going to try and find them nuts-n-bolts dirthualers talkin bout...chris
   / Cruse control on HST #7
cruise control?? must be near the heated seat switch.
   / Cruse control on HST #8
ROTFL :)
I guess you don't use no stinkin' cruise control?
Haven't used mine yet but am just waiting for a neighbor's call "Rex, can you drive over and (FillInTheBlank) for me?" Then I'll get some use from it.
   / Cruse control on HST #10
If it is set at too low of pedal travel it won't hold.
It can also be adjusted.
BTI
Detach Trailer (A50514)
Detach Trailer...
Portable Cattle Loading Shute (A50515)
Portable Cattle...
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A50324)
2019...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
2005 Sterling Semi (A50514)
2005 Sterling Semi...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
