Cruse control on HST
   / Cruse control on HST #1
Hoffie
Southcentral Pa
Kiota CK25
Does anyone use it? When & why? On by CK25 it does not work, that is it gradually slows down and stops.
   / Cruse control on HST #2
I don't have the HST but I remember a post awhile back of someone having the same issue on a 25/30 and it came to getting under the "dash" and tightening the nut(s) on the control lever to put more "tension" on the lever so as not to allow it to back off on it's own when engaged (same as the throttle control on the gear drive). I had to back mine off on my gear drive, which was a pain in the butt to get to! Hope this helps ya.
   / Cruse control on HST #3
I rarely use mine, but when I do it is great. My sister has a house 1 mile down the road (paved) and when she needs work done, like fixing a washed out driveway, I put it in 2wd and high, set the rpms at 2800 and set the cruise at full pedal. It really takes the strain off the ankle. I like it but could live without it.
I'm not sure it's worth messing with.
   / Cruse control on HST #5
I use mine all the time, mowing, going down the road,etc.
   / Cruse control on HST #6
ditto my ck25 does the same thing,i would like to use it when im mowing,so im going to try and find them nuts-n-bolts dirthualers talkin bout...chris
   / Cruse control on HST #7
cruise control?? must be near the heated seat switch.
   / Cruse control on HST #8
ROTFL :)
I guess you don't use no stinkin' cruise control?
Haven't used mine yet but am just waiting for a neighbor's call "Rex, can you drive over and (FillInTheBlank) for me?" Then I'll get some use from it.
   / Cruse control on HST #10
If it is set at too low of pedal travel it won't hold.
It can also be adjusted.
BTI
2015 John Deere 135G Hydraulic Excavator (A50322)
2015 John Deere...
ST205/75R15 Tires (A47384)
ST205/75R15 Tires...
(4) 10' High Pole Swinging Gates (A50515)
(4) 10' High Pole...
2015 Acura MDX SUV (A50324)
2015 Acura MDX SUV...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
