CRUNCHING REAR HUB?
   / CRUNCHING REAR HUB? #1
stuiedavis
dublin, ireland
international 674
Hey folks!
my international 674 is going well... but!
there is a grinding sound from the left rear hub... im thinking that its the
wheel bearing... new to tractors and before i go getting wheel off to inspect
id would appreciate if anyone has had this type of issue and how they solved
it?
i have been looking online and cant find international 674 rear wheel hub for sale!
thanks for reading
   / CRUNCHING REAR HUB? #2
Check to make sure the wheel rim bolts are good and tight. Hopefully that's what it is, and not a bearing going out.
   / CRUNCHING REAR HUB? #5
That bearing has a 21MM I.D. A rear axle bearing for your tractor is much larger. Forget the bearing until you check the wheel.
hey folks
i have the wheel off... the nuts came loose by just standing on the rachet and a wee bounce
thought that it would be much harder but they were tight... there is a little in and out play when i pull/push the disc
forgive my ignorance on this but i cant see how to get disc off to expose hub!
again thanks very much for the help... its much appreciated
PS im picking up an international front loader tomorrow :)
i cant see how i get the cap, disc, hub off to expose bearing
ah the whole half axle comes off!
outer bearing knackered
part ordered :)
2023 Ace Cargo 6x12 Food Trailer (A51572)
2023 Ace Cargo...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A52576)
2005 INTERNATIONAL...
New/Unused Forklift Jib (A51573)
New/Unused...
Ryobi Sliding Miter Saw (A51573)
Ryobi Sliding...
