Rhino35
Bronze Member
Fellow Safety-Minded Forumites,
I'm about to start my second ever bush hogging adventure and do my hills again (those cursed hedge apple saplings are shooting up again), and in the interim I've been scouting this forum and researching wheel spacers (will order some today) for cautions. One thing I thought about since I bush hogged was that my new tractor has a cruise control. It is a magnet that when a rocker switch is engaged holds the hydrostatic go forward pedal in place. When you switch off the rocker switch it releases and the spring in the pedal will stop the tractor. When you hit the brake pedal it releases the magnet. It does not work in reverse.
It's a nice feature. Gives the leg a rest. I used it crawling up and down the hills having a blast chopping hedge apple saplings to tiny pieces. Did I say I hate hedge apple trees?
So in my stability research and spacer quest for information I saw an article that said that a tractor can go from level to the point of no return in a vertical backwards rollover in three quarters of a second! If your rear wheels are stuck in ice, or you attach a tow cable too high behind the tractor and the load doesn't move, or you're bush hogging and the back lip of the bush hog catches a stump and the tractor stops abruptly. Maybe even if you pop the clutch!
Both my neighbors are experienced tractor drivers and both have almost gone over backwards. One was the catch the stump scenario. The other caught a rock just right. They had manual transmissions and instantly knew to depress the clutch. The nose came up and banged back down.
So it occurred to me that using cruise control going uphill while bush hogging might be a pretty bad idea. I'm already 20-30 degrees nose up. I have the empty FEL low, but still a couple of feet above the ground because the bushes were that high. If I caught something the cruise control won't care. I could hit the brakes and that should release it, but who knows? I probably won't be able to reach down and click off the rocker switch in time. The fastest, and simplest, and most intuitive reaction to the nose coming up would be to pull my foot back and off the go forward pedal.
I thought I'd post my little safety insight in case other newbies are using cruise control like I...was!
Best,
Rhino
Best,
Rhino
