Buying Advice (crosspost) 1600 vss
   / (crosspost) 1600 vss
Very reliable. I know several folks down here that have them on 1400 and 1500 series tractors. Most hours I know of on one is about 1900 with no problems on it or any of the others.
Good to hear. Not knowing much about shuttles (power or otherwise), I've been trying to get educated on them. I'm already past any concern about loader use, having tried that out. Then it was onto woods use (jury's still out on that one), and maintenance. Seems like the only maintenance item is really the power shuttle's clutch, and its life would probably exceed my use.
   / (crosspost) 1600 vss #12
(crossposted from Kubota forum)
I drove the Masseys today. I have to say in most respects I liked them a lot more than expected, which took me by surprise, actually, as I've been a Kubota fan for a while. Fit and finish of the MFs is superb, the cabs are spacious, the controls fit and felt better to me, and forward visibility was noticibly better than the Grand L's. The ride was smoother with less porpoising on the MFs. It was the forward/back porpoising as well as some side-to-side roll in the Kubota L's that gave the impression of top-heaviness. I didn't notice it in the MFs. The only thing that seemed slightly cheap on the MF cab were the quarter window latches. I preferred the MFs plastic seat after seeing a couple of used tractors with fabric seats. I bottomed out the Kubota seats on a couple of ruts - didn't happen in the MFs. The position control setting on the MFs didn't budge, where I could hardly get the L's setting NOT to move, no matter how gently I moved the lift control.
Loader performance seemed about the same between both lines, with a slight edge to Kubota. Cab access is slightly better on the Kubotas, I think, as are the larger sizes of the openable windows. The L's heater is better and quieter.
I didn't like the MF HST very much. It was very whiny. The side by side pedals don't do anything for me and, if anything, I think they could be dangerous. The Kubota Grand L's are CLEARLY the better choice in an HST.
On the other hand, I liked the MF power shuttle a lot. Very smooth forward and reverse and for loader work, where you'd be using the foot throttle, it's as easy as a hydro - think a flick of your hand instead of moving your foot. The clutch is also very light (non-tiring), and you can feather the speed very precisely to sneak up close to something.
The MFs loader frames seem phenomenally heavily built. They also extend to the rear of the tractor. Hydraulic components seemed very rugged also. One thing I did NOT like on the MFs, however, is the reliance on hoses instead of hard lines, and in particular, the loops of hose (for the loader) hanging below the frame - just waiting to get snagged.
The dealer had them pretty well spec'd as-is on the lot, including stereo in the cab, filled tires or weight box (my choice), heavy-duty bucket (w/cutting edge), and a couple of rear remotes. The last struck me as odd, though, as the MF brochure lists a 3-spool setup as optional, not 2.
Price? Seemed high - 29,950 for a 1635 with loader & powershuttle.
Talked to my local dealer today about a 1652 Cab with Dyna QPS transmission, R4 tires and DL130 Loader with skid steer quick attach bucket. One rear remote is standard with MF cab models.
With the current MF free front end loader promotion, cash price is just under $30,000. Financed at 0% for 72 months is right at $35,000. This was the first price he gave me - no haggling or negotiating yet.
sf
John Deere (A50322)
John Deere (A50322)
2013 Chevy Silverado 2500 HD (A55218)
2013 Chevy...
2025 GIYI SGB20 20in Single Cylinder Stump Grapple Bucket Skid Steer Attachment (A53421)
2025 GIYI SGB20...
UNUSED LANDHONOR HPF-11-3000G HYD PALLET FORKS (A54757)
UNUSED LANDHONOR...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55218)
Galvanized...
2001 JOHN DEERE 310G BACKHOE (A52705)
2001 JOHN DEERE...
