Crossbow mix ratio
/ Crossbow mix ratio #1
Alvito
75tn new holland
What is crossbow herbicide ratio mix to clean fence row growth ....multi flora rose, tree seedlings, Canada thistle, etc....and not damage hay field grasses snd best time to spray
/ Crossbow mix ratio #2
Page 7, If you have the money, 3 oz/gallon would be a pretty hot mix. Otherwise 2oz/gallon will kill what you listed.
Best if no wind, high humidity - like you can get towards night fall or early morning... Label says you can spray up to 10 mph wind but I would not risk it.
Don't spray in the heat of the day with low humidity!!!
What are your spray droplets like? Do you know? You want larger droplets, you do not want a fine mist!!!
You don't need to soak the leaves, a little can go a long way. You can always reapply what doesn't get killed.
Thanks for valuable information I could never get from a label, you covered a lot with few words, thanks again
1143 (A63745)
1143 (A63745)
Year: 2010 Make: Kia Model: Soul Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 173,262mi Plate: (A66738)
Year: 2010 Make...
FUEL TANK WITH PUMP (A68842)
FUEL TANK WITH...
JCT 72" Rotary Mulch Head (A64912)
JCT 72" Rotary...
Mahindra 4550-4L Loader (A64911)
Mahindra 4550-4L...
2014 MAC FLAMELESS HEATER  (INOPERABLE) (A68842)
2014 MAC FLAMELESS...
