Creeping throttle on PT 1430
   / Creeping throttle on PT 1430 #1
RegL
Platinum Member
Northwestern CT
PT 1430
Hi all,
Put another couple of hours of field mowing on the new tractor with no apparent problems, just one little thing thats a bit annoying, and maybe it's just normal. Seems the throttle doesn't want to stay at anything over about three quarters. when I put the lever above that to get more rpms, it just creeps right back. Could be govorner action but I've never seen one move the throttle cable back. Have not really looked at it yet but was wondering what others have experanced. Thanks.
   / Creeping throttle on PT 1430 #2
I have had the same experience (on an 1845). There is a tension adjustment on the underside of the throttle control. Just remove the panels to access the underside of the instrument panel. Mine takes a 7/16" wrench--front and back. It is a little awkward to get the back side nut but doable without removing anything more than the access covers.
Thanks Bob, that fixed it.
   / Creeping throttle on PT 1430 #4
Bob,
Even though I was not part of this discussion, I also thank you for posting the solution. I too have had the throttle creep issue on our 2445. I'll tackle the fix as soon as I can.
Sabi
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
378789 (A51573)
378789 (A51573)
TRUCKING INFO (A50775)
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
378585 (A51573)
378585 (A51573)
2023 LMC M40018 LOT NUMBER 176 (A53084)
2023 LMC M40018...
