Creeping forward with a shuttle shift
   / Creeping forward with a shuttle shift #61
Jftr, my only point was that HST is not "more accurate" or "precise" than clutch. That is the only point I was trying to make. If you think otherwise then you can't operate a clutch and brake well.
Then the fanboi club met and attempted to prove that HST is better than gear. Again.
   / Creeping forward with a shuttle shift #62
JFTR, nobody said HST was more precise than gear before your comment about that topic. YOU were the one that started the argument by bringing up a comparison between the two types.
TripleR said he wouldn't try it with his Kubota, but it could be done by riding the brakes. He never said it couldn't be done, just that it wasn't worth his time.
I still don't own an HST machine.
   / Creeping forward with a shuttle shift #63
GManBart, we need more grown-ups in this world like you:thumbsup:
   / Creeping forward with a shuttle shift #64
I just read most of the thread again. I didn't derail it. The slow video guy did, as far as I'm concerned. I just made a snide comment due to the prevailing attitude on this board regarding the supposed superior positioning ability of hst transmission tractors over all other types. That idea is simply false as noted by several members in this thread. Why do you think the OP even asked the question if he didn't read it or hear it somewhere? He got a correct answer immediately from the second poster. Then the faulty/poor Kubota wet clutch thing came up and off we went...
I probably shouldn't have made that comment, but at least I didn't feel compelled this time to say what DickFoster said. Which is exactly what I said the last time I tried in vain to bury the misinformation.
There's another thread going about a little gear Kubota that was traded for an HST for a good reason to need the HST. That makes sense.
But it doesn't make sense to avoid a clutch because the machine can't be put where you want to put it. That idea is simply wrong.
More accurate; Right. Only if you can't drive a clutch, which isn't very hard.
Ok. I am done till next time someone asks that question which only comes up due to misinformation propogated mainly on this board, as far as I can tell.
Go to a farmer's board and the truth surfaces right away. Just like it did here in the second post. Perhaps the following crappy Kubota clutch reply should have been qualified more. Then I would have stayed out of it.
Glad i now know that about those Kubota models. Hopefully that issue is solved in the newer ones.
Anyway, I gotta get back to moving bales. I hope i don't crash into something with my standard transmission inaccuracies.
   / Creeping forward with a shuttle shift #65
Another interesting task is using pallet forks. Right now, with my B7800 (HST), I've been standing up so that I can look down at the forks as I push them under pallets (lining them up). I'm driving the tractor standing up. With the HST I need only tap the travel pedal to nudge the tractor forward (keep in mind that there's a fair amount of correction happening because I'm not on a solid, smooth surface). I suppose that one could do this with a gear tractor, but it certainly doesn't seem as though it would be as "easy."
I never advocate for anything (unless it's something that I sell). Too many variables, and broad-brushing is always problematic.
Is this thread flogged to death yet?
   / Creeping forward with a shuttle shift #66
Apparently not.
Good point. Although with creeper gears it's pretty close when standing up because creeper 1st is pretty darn slow (but maybe,barely not quite as "slow as you can go")
Couldn't help myself
   / Creeping forward with a shuttle shift #67
Two good points out of all of that.
   / Creeping forward with a shuttle shift #68
What are you talking about? You're still derailing the thread. The question was simply whether you can creep up on something with a shuttle shift. The first person to make the comparison to HST was you, for no reason, with the comment even you have said was snide.
This is a compact tractor forum. Yes, you will hear different opinions than you'll find on a big Ag forum. Big Ag tractors almost never have to be super precise where an inch or two means some kind of dent in something you don't want dented. Hooking up to implements isn't a precision event....if you bump them, they don't break.
If you were to go to a heavy equipment forum, you'd find different opinions there as well. In fact, there they talk even more derisively of anything but HST systems. Nobody in construction wants anything but HST type systems now...faster, more productive, easier to be precise, etc, but that isn't what this forum is about.
Lastly, you talk like operating a shuttle like there's no chance a skilled operator can make a mistake....not true. I was using my backhoe, which has a power shuttle with no clutch pedal, to load something recently, and my foot slipped on the brake pedal. I guess I had a little mud on my boots, and the soles are a bit worn, and I put a dent in the trim of my barn door. That would have never happened with an HST system...go figure. If you make a mistake with an HST system, the machine stops moving. If you make a mistake with a shuttle, stuff gets broken, you stall the engine, or you just look stupid....it happens to everyone sooner or later.
   / Creeping forward with a shuttle shift #69
I am buying a tractor soon. I have driven HST's before but don't have much first hand experience with a shuttle shift or power shuttle. Long term I plan to do quite a bit of field work and things where I would prefer to have a shuttle shift. I also plan to snowplow my driveway and other around the house tasks from time to time.
My question is how hard is it to creep forward with a shuttle shift. Lets say I am a foot from my garage door and I want to creep forward that foot to put the FEL down and pull snow back. I have driven plenty of manual transmission vehicles. Would creeping forward that foot be similar to driving a manual transmission vehicle where you just let off the clutch a bit or does a tractor drive differently to where it would be hard to do that.
In short, it's not that hard, just use the clutch as stated ( in first gear). But personally, a foot near the garage door is cutting it close, I would do that extra foot with the shovel.;)
   / Creeping forward with a shuttle shift #70
I have a "Shuttle Shift" and can tell you that with my tractor there has been no issue with speed; fast or slow.
My bucket is just barely narrower than the French doors that lead into my house. I use the tractors loader to transport wood from the wood pile to just inside these French doors. There is no room for (me) to pass once the bucket passes the door casing, the wife takes over in her socks and loads the staging area beside the wood stove. I use a higher gear during transport but switch to low gear to navigate the tight opening. Works great for us as it reduces debris that would normally get tracked in.
When loading material in a truck bed, the same process is used. Slow for finite tasks and fast for transport; albeit a lever must be moved first and a brake depressed to perform the job at hand.
You made the comment about "life expectancy of a HST", I can not answer that as it is relatively new technology in a tractor; time will tell. However, there is turn of the last century equipment that is still out there doing work with gear transmissions. I have no issue with any of the transmission variations but logically chose a tractor with the gear tranny based on track record alone. Although.... I am sure the HST would be much more user friendly!
2008 JOHN DEERE 310SJ BACKHOE (A52709)
2008 JOHN DEERE...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
Mini John Deere Truck (A55853)
Mini John Deere...
2006 Dewatering and Drying Centrifuge (A56857)
2006 Dewatering...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2017 FREIGHTLINER...
