Creeper Gear 120 hp tractor needed
/ Creeper Gear 120 hp tractor needed #1
Eduardo Pflucker
Looking for a 100 - 120 hp tractor with Creeper Gear to run a Stone Crusher.
/ Creeper Gear 120 hp tractor needed #2
i dont know how slow you are needing to go but i do know that the New Holland T6000 series, in low gear at 2200 rpm you run 1.3 miles an hour. they do offer a creeper gear with a 32f and 32 reverse trans
that series tractor is from 90pto hp to 130 pto hp
/ Creeper Gear 120 hp tractor needed #3
find a ford 8210 or tw series with dual power and the dual power is a really low gear or a newholland 8010 low profile they had a creeper gear and the nh tv140
/ Creeper Gear 120 hp tractor needed #4
Almost all tractors in that hp range can be fitted with a creeper. The masseys have both creeper and super creeper options (super creep is ft per hour sort of creep). Kubota the same, Case/IH, NH as well.
Around here its all Valtra's on stone crushers because of the reverse drive station.
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
Mahindra 6065 (A62177)
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59909)
2016 FREIGHTLINER...
2014 Chevrolet Caprice Sedan (A61569)
2014 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
