Creek Crossing with Soft Banks
   / Creek Crossing with Soft Banks #11
The Corp of Engineers can get involved into to any thing that carries water. A friend wanted to build a small dam across a low place on his property to back up less than an acre for a pond. Water was run off and it dried up about 4 months in the year. Less than 1 inch deep and only about 24 inches across at the widest. Said it was a wet land. Only low place going thru the woods. Dam would have stopped the land from washing away and given him a way to cross without going thru it.
   / Creek Crossing with Soft Banks #12
How long of a bridge would you need to get from good ground to good ground?
Creek of 3ft does not sound like much of a challenge. The city telling me I could not have a bridge of any kind on my property would incentivize me to get real creative real quick.
I would build a trailer of sorts that I could push in and pull out with the tractor at will. When they ask tell them you don’t have a bridge you have a trailer. It could be built in a way that uses a roller instead of wheel so it does not sink in the mud.
   / Creek Crossing with Soft Banks #13
There are power lines and such so I'd like to clean it up before I get everything growing up into them.
The utility companies came through and cut a path and crossed with a tracked skid steer with no issues.
Why do you want to clean it up for the power company?
Bruce
I wasn't really sure who was responsible for the lines and what grows up into them. I figured it would be easier form me to mow it down and then give in an annual cutting vs. waiting until none of it is movable. I know I have a hydrant and water shutoff in that area and those I keep chopped down and sprayed around them.
I would guess around 10' would be pretty safe most times of the year. I cut stuff like this in August usually or early fall so it tends to be drier. Not sure how that is going to go this year with all the rain.
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A55851)
2016 Godwin CD150M...
Magnum 4000 Series Hot Water Pressure Washer (A47477)
Magnum 4000 Series...
Kohler power system 200 generator (A55787)
Kohler power...
Hose Reel (A55787)
Hose Reel (A55787)
2016 Infiniti Q50 AWD Sedan (A55758)
2016 Infiniti Q50...
2012 Freightliner M2 112 Fuel and Lube Truck, VIN # 1FUGC5DV5CHBF7397 (A54865)
2012 Freightliner...
