crankshaft nut
/ crankshaft nut #1
takins
does anybody know what size the crankshaft nut is on my 2210d?
I need to turn it to set valve clearance.
/ crankshaft nut #2
it is really big, I had nothing to turn it. Hopefully someone here will know what size it is. I had to use a oil filter drain wrench with the chain on it to turn the motor over. Worked pretty good but I did have the radiator off so it was easy to get too that way.
good luck
Erick
/ crankshaft nut #3
If you pull the compression release, it isn't that tough to turn with the belts.
Kubota ZG222 (A60462)
2017 Peterbilt 320 T/A Heil 28Yd Front Loader Garbage Truck (A61573)
2017 Peterbilt 320...
John Deere Gator (A64119)
John Deere Gator...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
(1) UNUSED 31X13.50-15 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED...
1996 International Water Truck with a Caterpillar Engine (A63688)
1996 International...
