crankshaft nut
   / crankshaft nut #1
takins
does anybody know what size the crankshaft nut is on my 2210d?
I need to turn it to set valve clearance.
   / crankshaft nut #2
it is really big, I had nothing to turn it. Hopefully someone here will know what size it is. I had to use a oil filter drain wrench with the chain on it to turn the motor over. Worked pretty good but I did have the radiator off so it was easy to get too that way.
good luck
Erick
   / crankshaft nut #3
If you pull the compression release, it isn't that tough to turn with the belts.
2014 FREIGHTLINER CASCADIA MID ROOF SLEEPER (A54607)
2014 FREIGHTLINER...
2007 Yamaha Rhino 660 (A53473)
2007 Yamaha Rhino...
Light Tower (A52377)
1994 MACK RD688S BOBTAIL VACUUM TRUCK (A53843)
1994 MACK RD688S...
