Crankshaft alteration
   / Crankshaft alteration #1
plastikosmd
Veteran Member
Feeling better today
I have an onan that needs to go from one machine to another. The problem is the good motor only has a short taper not straight shaft.
the donor has a blown motor and spun bearings so crank swap wasn稚 possible
So an attempt at a budget salvage
So I cut off the straight portion of bad crank, drilled to accept the 3/8 bolt that taper crank is tapped for and then bored the taper
Run out is 0.002, next to get a 5” 3/8 fine bolt to hold on the taper and then decide if I cut a secondary key or weld
run out is so good, welding concerns me but hand cutting that keyway on the crank is going to be a pain. It would also be a custom key, straight transitioning to 1/2 moon on high side of taper
Shaft may see some shock loads
Will see
   / Crankshaft alteration #3
If you have a good taper bored and the parts fit good, a green Loctite bearing retainer might hold. Call them. Removal of bearings that have been "retained" are nearly impossible to remove without heat.
Retaining Compounds - Henkel Adhesives
Takes a whack with a hammer to free it up, good thought and thank you
I would prefer it to be gripping on the taper rather than a weld at the end and along the old keyway. It would be less stress risers. I half heartedly considered rusting the two things together with the single end bolt to support and hold compression LOL
   / Crankshaft alteration #5
Your sleeve fix is weaken by the existing keyway in it as the wall thickness is very thin. Maybe a thru dowel toward the end?
Only at the edge, the hole is tapered also
That was my consideration on in welding it up, I just don’t think the distortion is worth it.
Basically is is this minus the 61$ to buy it
Crank shaft Adapter Taper to 1 1/8" Inch Generator Pressure Washer Engine | eBay
They kept it as straight key and tapered that also as not to engage the crankshaft. I may want to tie it it or just go w end bolt and taper. A good taper match should hold quite well, just like all my milling machine heads
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A53426)
2014 HINO 338 26FT...
1992 GROVE AP-308 CRANE CRANE (A53426)
1992 GROVE AP-308...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
Can-Am BRP Side-by-Side (A51694)
Can-Am BRP...
