Crank case breather kohler
   / Crank case breather kohler #1
bert55044
I have a 18hp kohler that blows the dip stick out of the engine, when I start it in cold weather. It is a k361QS, I have removed and clean the vent, it will help for a couple of cold weather starts then the problem returns. I put the dip stick back in the engine and it runs fine... when it is warm I don't have this problem.
   / Crank case breather kohler #2
Try a thinner oil or use synthetic. That might help you.
   / Crank case breather kohler #3
I have a JD 312 with a 12hp Kohler it did that a couple of time last year or the year before. Hasn't done it again. Don't know what caused it. Once it started it would suck the dipstick back in tight. I wonder what the cause is myself.
I will try lighter oil that is synthetic and I will let you know if it helps. I am sure that Minnesota will let me test it in some cold weather in the next couple of months. thanks
Toro Mower (A50324)
Toro Mower (A50324)
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2002 INTERNATIONAL 4400 BEVERAGE TRUCK (A52576)
2002 INTERNATIONAL...
2023 JOHN DEERE 8R370 LOT NUMBER 219 (A53084)
2023 JOHN DEERE...
2019 KOMATSU WA320-8 WHEEL LOADER (A51246)
2019 KOMATSU...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
