Crank case breather kohler
   / Crank case breather kohler #1
bert55044
I have a 18hp kohler that blows the dip stick out of the engine, when I start it in cold weather. It is a k361QS, I have removed and clean the vent, it will help for a couple of cold weather starts then the problem returns. I put the dip stick back in the engine and it runs fine... when it is warm I don't have this problem.
   / Crank case breather kohler #2
Try a thinner oil or use synthetic. That might help you.
   / Crank case breather kohler #3
I have a JD 312 with a 12hp Kohler it did that a couple of time last year or the year before. Hasn't done it again. Don't know what caused it. Once it started it would suck the dipstick back in tight. I wonder what the cause is myself.
I will try lighter oil that is synthetic and I will let you know if it helps. I am sure that Minnesota will let me test it in some cold weather in the next couple of months. thanks
2023 LMC M40018 LOT NUMBER 176 (A53084)
2023 LMC M40018...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
New/Unused 250 PVC Safety Traffic Cones (A51573)
New/Unused 250 PVC...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
2010 TAKEUCHI TB235 EXCAVATOR (A51246)
2010 TAKEUCHI...
66 Tomahawk Skid Steer Bucket (A52384)
66 Tomahawk Skid...
