Crank Assembly wont rotate
   / Crank Assembly wont rotate #1
Tobias_Eaton
Ferguson TO 30
Hello, rebuilding a Ferguson TO30- 4 cylinder, Crank is installed and main caps are torqued, clearances checked and it rotates no problem (no pistons)
Installed the pulley and torqued Crank nut to 130 ftlbs but won't rotate, still no pistons. I back off the Crank nut to finger tight and the Crank can be rotated again. Is this normal?
   / Crank Assembly wont rotate #2
Probably not normal.... Sounds like pulley is bottoming out on a bearing cap or pushing timing chain pulley against bearing cap or pulling crank laterally against its thrust bearing....
Hmm yeah that's what I was thinking
It's an aftermarket pulley, the OG one snapped on the front being removed, but shaft measurements are the same, guess I could reinstall the OG and see if I have this issue.
Thanks for speedy reply
Ok will do
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A53421)
2025 GIYI GY-BK56M...
1996 International Water Truck with a Caterpillar Engine (A55218)
1996 International...
Hyster H225E Forklift (A47477)
Hyster H225E...
2017 Caterpillar 326FL Hydraulic Excavator (A53421)
2017 Caterpillar...
2012 DOOSAN G25KW GENERATOR (A53843)
2012 DOOSAN G25KW...
