Crank Assembly wont rotate
   / Crank Assembly wont rotate #1
Tobias_Eaton
Ferguson TO 30
Hello, rebuilding a Ferguson TO30- 4 cylinder, Crank is installed and main caps are torqued, clearances checked and it rotates no problem (no pistons)
Installed the pulley and torqued Crank nut to 130 ftlbs but won't rotate, still no pistons. I back off the Crank nut to finger tight and the Crank can be rotated again. Is this normal?
   / Crank Assembly wont rotate #2
Probably not normal.... Sounds like pulley is bottoming out on a bearing cap or pushing timing chain pulley against bearing cap or pulling crank laterally against its thrust bearing....
Hmm yeah that's what I was thinking
It's an aftermarket pulley, the OG one snapped on the front being removed, but shaft measurements are the same, guess I could reinstall the OG and see if I have this issue.
Thanks for speedy reply
Ok will do
2019 New Holland C227 Skid Steer (A50657)
2019 New Holland...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2025 K2223 UNUSED Double Garage Metal Shed (A50860)
2025 K2223 UNUSED...
2019 Ford Transit 150 Cargo Van (A48081)
2019 Ford Transit...
2019 Ford F-550 Bucket Truck (A51039)
2019 Ford F-550...
2016 Ford Escape SUV (A48082)
2016 Ford Escape...
