Craftsman with Kohler SV590 will only sputter Help!
   / Craftsman with Kohler SV590 will only sputter Help! #1
gdrepair69
High Point, NC
Kabuta
ot a craftsman here 2004 with SV590 19 Hp Kohler. Its getting spark, by-passed any fuel issues by using start fluid directly into the carburetor mount, it will sputter a little then thats all. Should make it fire to 2-3k rpm? Basic compression test with one of those that you screw in the hose with a coupling to connect the pressure gauge. Spinning it over few times it goes to 60 psi the 90 psi on next rotation. So not sure where to go from here? Got spark, got starting fuel & unless Im wrong, got compression. Any intelligent help would really be great. :confused3:
   / Craftsman with Kohler SV590 will only sputter Help! #2
God I hate Kohler motors.. Good luck.
Thanks everyone, I pulled the valve cover to find the intake rocker & push rod had jump off! Will reset, adjust clearance and hope it fires up...
John Deere 310K Backhoe (A51573)
John Deere 310K...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2024 JOHN DEERE 8R 280 LOT IDENTIFIER 7 (A53084)
2024 JOHN DEERE 8R...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2011 FORD F-450 (A52472)
2011 FORD F-450...
JOHN DEERE 1700 LOT IDENTIFIER 17 (A53084)
JOHN DEERE 1700...
