Craftsman saw runs short time and quits
   / Craftsman saw runs short time and quits #1
Big Joe
Fayette County, TX
L4300DT
My Craftsman (Poulan I'm sure) saw runs for about a minute and then quits. It will not start for quite some time afterwards and then quits again. Help!
   / Craftsman saw runs short time and quits #2
Sounds like fuel starvation.
Could well be the filter which you will find dangling in the tank at the end of a soft line.
Fashion a hook and fish it out then blow it clean or replace it.
Or flooding.
Other possibility is the air filter that if clogged with sawdust will act like a choke and flood the carburetor.
Solution is to clean it and re-install.
With starvation there would be no fuel smells while flooding will some spilled gas.
   / Craftsman saw runs short time and quits #3
If it is getting hot and then quits, clean out the muffler screen behind the muffler
   / Craftsman saw runs short time and quits #4
Just throwing this out there also. Whens the last time the carb has had a kit put in it.
With todays gas the diaphragms harden up pretty quickly when stored with gas in them.
   / Craftsman saw runs short time and quits #5
Or flooding.
I'll second the filter
Our Craftsman actually had the filter come off so the pick-up was low and the filter would clog the line from time to time.
Thanks guys for the good info. I pulled the pick-up filter and used the compressor to blow it out, but the same thing happened. I will buy a new one and see if that works. I guess pumping the primer bulb provides enough pressure to pump the gas to the carb, but the filter is too clogged for it to continue on a normal basis. The carb was cleaned and the fuel lines were replaced awhile back. I will let you know how the new filter works.
   / Craftsman saw runs short time and quits #7
If the fuel lines and filter all check out to be good, and you find that it is in fact a fuel delivery problem, then check the carburetor, once having removed the carb. split it and you'll find a small screen inside at the fuel inlet, chances are this screen has become clogged, ;)
The stone filter in the tank does catch most all things although some small particles can make its way to the screen and clog it up over time,
   / Craftsman saw runs short time and quits #8
I'll add another possibility.
Some fuel lines will deteriorate with new alcohol based gas and then plug the jets.
Rubber lines are the worst for that.
2016 Komatsu WA380-8 Articulating Wheel Loader, S/N 15080, PIN# KMTWA13OCGA015080, Turbo Diesel (A59076)
2016 Komatsu...
Automatic Tire Changer (New/Unused) (A59225)
Automatic Tire...
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
Giyi 27" Mixing Bucket (A57149)
Giyi 27" Mixing...
