Craftsman Riding Mower Bad Ground?
   / Craftsman Riding Mower Bad Ground? #1
slowgsxr97
Central Illinois
New holland mc28
Hello, I just got a craftsman LTX1000 to fix. Its a 1998, 20hp Intek, model # 917.272432
Runs great. Problem is You have to Press the brake to start which is normal. When you let off the brake the mower does not shut off. It lugs down a bit, while its sitting there lugging if you push on the seat to activate safety switch it runs right again.
Also when you turn the mower off it lugs down and takes about 10 seconds to shut off.
Wiring doesn't look tampered with. I wanna fix it so all safety switches work properly. Maybe a bad ground? Any advice on where to start. I have already tried the ignition out of another LTX1000 I have at the house right now. It was not the problem.
Thanks in advance, Jeff
A little investigating this evening, found a broken wire at the spade connector on the right coil. 15 minutes and a new connector later, All safety work and shuts off as it should. I'm glad I got an easy fix for once.
78'' root grapple (A53421)
78'' root grapple...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
2018 FORREST RIVER CRUISE LITE CAMPER (A53843)
2018 FORREST RIVER...
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
100 GAL FUEL TANK W/PUMP TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
4 TON PORTAPOWER (A53843)
4 TON PORTAPOWER...
