Craftsman GT - motion drive belt jam
   / Craftsman GT - motion drive belt jam #1
c3c1
DFW, TX
Multi
I purchased a used Craftsman GT Hydro with 50 inch deck. I think I now know why it was for sale.
Early on the motion belt jumped off the pulley on the transmission, jammed behind the pulley and burned up. It was not real old, but torn up, so I replaced it. About 6 hours running later (3 weeks), it has jumped off again and jammed in the same place. I was quick about shutting down and pushing to the shed. I use the clutch/brake as I mow, and this happened when I did a stop/start to lean and grab a branch/trash. Same the earlier jam.
Since I replaced with the correct belt, is there an adjustment or spring needing replacement to avoid this?
   / Craftsman GT - motion drive belt jam #2
Make sure that the belt guides are in place around the tranny pulley. Also make sure that the transmission support bracket has not come loose. If the bracket has come loose the tranny can rock back and forth throwing the belt off of the pulley.
Interesting, there are no belt guides near the tranny pulley. I don't even see a place where one might go, or have gone. There is no movement in the tranny position. If I could figure a way to place a belt guide behind the pulley, that would fix it.
   / Craftsman GT - motion drive belt jam #4
Check parts drawing for guides. The previous owner may have removed them.
CATERPILLAR 140M2 MOTOR GRADER (A52706)
CATERPILLAR 140M2...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
2014 CHEVROLET IMPALA 4DOOR SEDAN (A54313)
2014 CHEVROLET...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A55218)
2022 Gravely...
2017 Kubota M5-111D 105HP Agricultural Tractor (A52377)
2017 Kubota...
