Craftsman DYS 4500 seat switch
   / Craftsman DYS 4500 seat switch #1
millwrightdude
I would like to know how to disable the safety switch under the seat.
   / Craftsman DYS 4500 seat switch #2
You have two choices. If unplugging the switch does not work, make a "jumper" to replace the switch in the wiring harness.
   / Craftsman DYS 4500 seat switch #3
Does the seat switch wiring go to the bottom center of the seat? If so, its like mine. Remove the seat from the mount, remove the switch from the seat, use a cable tie to hold the switch plunger depressed, lay the switch on top of the gas tank, remount the seat. The nice thing about doing it this way is if you want to restore the safety switch its just a matter of removing the cable tie and remounting the switch in the seat so save the mounting parts.
good luck
DanKtx
   / Craftsman DYS 4500 seat switch #4
I also have a safety switch problem, I think. The engine starts right up, but when I either engage the blades or release the clutch pedal the engine stops. I though that maybe it was the ignition swich, but now that I have read the post's, maybe it;s the seat switch. I did find the safety swich by the clutch pedal and jumped it, but it would not even start. I did notice that the switch under the seat looks bad, but, I did not jump that one yet. Were is this third saftey switch that you guys are talking about?
I followed the wiring harness all the way to where it pugs in near the starter. I unplugged it and that did the trick
   / Craftsman DYS 4500 seat switch #6
i had that exact problem on mine last year, turned out to be a relay that most of the switches go to, replaced it and no more problems.
   / Craftsman DYS 4500 seat switch #8
But, the switch has 5 wires going to it. The center wire is black. Now, how do you jump the switch?
JMR stump/trenching bucket (A53421)
JMR...
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
PALLET OF CHAINS AND BINDERS (A53843)
PALLET OF CHAINS...
377789 (A51573)
377789 (A51573)
255/70/22.5 TIRES (A53843)
255/70/22.5 TIRES...
