Craftsman DTL2000-Blowing Fuse
/ Craftsman DTL2000-Blowing Fuse #1
dbannister
craftsman dtl2000
This tractor ran great yesterday untill I was putting it up, then it quit. It was the 25amp fuse. I changed it today and went through a box of fuses. Sometimes it would let me go a couple of times around the yard, others it would blow when I started to go forward. It is a 20 hp Kholer and hydrostat. Any ideas on what the problem may be? I know it is something electrical, but what ro where to start?
/ Craftsman DTL2000-Blowing Fuse #2
The issue could be in two places. There is a relay. But there is also the electric clutch, if you have one, as opposed to the lever engage type. The electric clutch operates off a button on the dash and engages the engine to the cutting deck. Un plug the electric clutch and see if you have an operational tractor, although you will not be able to engage deck, of course.
Those clutches are $200 or more, btw.
/ Craftsman DTL2000-Blowing Fuse #3
Sounds like you have a wire being pinched in the harness some where. It doesn't take much of a nick in the wire to short out and melt the fuse.
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A60429)
2007 CATERPILLAR...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
2023 Case TV380 (A62177)
2023 Case TV380...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
2016 Ford F-150 Ext. Cab Pickup Truck (A61573)
2016 Ford F-150...
