Craftsman DTL2000-Blowing Fuse
/ Craftsman DTL2000-Blowing Fuse #1
dbannister
craftsman dtl2000
This tractor ran great yesterday untill I was putting it up, then it quit. It was the 25amp fuse. I changed it today and went through a box of fuses. Sometimes it would let me go a couple of times around the yard, others it would blow when I started to go forward. It is a 20 hp Kholer and hydrostat. Any ideas on what the problem may be? I know it is something electrical, but what ro where to start?
/ Craftsman DTL2000-Blowing Fuse #2
The issue could be in two places. There is a relay. But there is also the electric clutch, if you have one, as opposed to the lever engage type. The electric clutch operates off a button on the dash and engages the engine to the cutting deck. Un plug the electric clutch and see if you have an operational tractor, although you will not be able to engage deck, of course.
Those clutches are $200 or more, btw.
/ Craftsman DTL2000-Blowing Fuse #3
Sounds like you have a wire being pinched in the harness some where. It doesn't take much of a nick in the wire to short out and melt the fuse.
Takeuchi TB225 (A62177)
Takeuchi TB225...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A63688)
FRESHLY...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
2015 FREIGHTLINER CASCADIA 125 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A59911)
2015 FREIGHTLINER...
2014 Ford Transit Connect Passenger Van (A61573)
2014 Ford Transit...
