Craftsman 6000 ZTS wont crank.
   / Craftsman 6000 ZTS wont crank. #1
Gary Fowler
Super Star Member
Bismarck Arkansas
2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
I had to remove the "hood" in order to fix some cracked plastic. This required removing the switch wiring. When I was trying to plug it back in, I didn't notice that two of the blades were bent together so when I turned the key, it produced some smoke from under the engine where the starter solenoid is. I quickly unhooked it, found the bent blade, straightened it and plugged the wiring harness back into the ignition switch.
Now it wont do anything. I can jump the solenoid and make the starter engage and turn the engine but it wont start.
The question is does anyone know of a fuse etc that is in the ignition wiring that I may have smoked. I looked at all the wiring and did not find any melted wires or hot plastic but something let the smoke outs so now it wont work.
I am hoping someone here fixed a similar problem so I don't have to spend $100+ on a service call.
   / Craftsman 6000 ZTS wont crank. #2
check the resistance of the starter solenoid coil and work backwards
   / Craftsman 6000 ZTS wont crank. #3
Make sure you have both handles pushed all the way out.
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
2018 Volvo MCT 110C (A47477)
2018 Volvo MCT...
2019 Dodge Journey Crossroad SUV (A53424)
2019 Dodge Journey...
Dixon Pro ZTR 2560 Zero Turn Mower (A53117)
Dixon Pro ZTR 2560...
ALLISON TRANSMISSION (A53843)
ALLISON...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
