Craftsman 6000 ZTS wont crank.
   / Craftsman 6000 ZTS wont crank. #1
Gary Fowler
Super Star Member
Bismarck Arkansas
2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
I had to remove the "hood" in order to fix some cracked plastic. This required removing the switch wiring. When I was trying to plug it back in, I didn't notice that two of the blades were bent together so when I turned the key, it produced some smoke from under the engine where the starter solenoid is. I quickly unhooked it, found the bent blade, straightened it and plugged the wiring harness back into the ignition switch.
Now it wont do anything. I can jump the solenoid and make the starter engage and turn the engine but it wont start.
The question is does anyone know of a fuse etc that is in the ignition wiring that I may have smoked. I looked at all the wiring and did not find any melted wires or hot plastic but something let the smoke outs so now it wont work.
I am hoping someone here fixed a similar problem so I don't have to spend $100+ on a service call.
   / Craftsman 6000 ZTS wont crank. #2
check the resistance of the starter solenoid coil and work backwards
   / Craftsman 6000 ZTS wont crank. #3
Make sure you have both handles pushed all the way out.
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
Vacuum pump (A53117)
2011 Ford F-350 Knapheide Stakebed Truck (A52377)
2011 Ford F-350...
2016 FORD F550 SUPER DUTY SERVICE TRUCK (A51406)
2016 FORD F550...
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
