Double J Creations
Hello all new here. I have a Mahindra 7060, bought it new and now have about 140 hours on it. It's making a cracking noise at the center of the right rear wheel/axle as I'm driving the tractor. I have checked for obvious things such as loose lug bolts, made visual checks for cracks or oil leaks around the axle and wheel. Jacked the tractor wheel off the ground, turned the wheel, the noise is not as pronounced but I still hear the noise. What could this be a bearing shelling out inside the axle housing or what? I use this tractor for shredding my fields and has a bucket that I occasionally move dirt around to fill holes and such, so not used really hard. Has someone here got an idea what the noise could be or had experience with this before?
