Cracking front wheels
/ Cracking front wheels #1
Cormac
Park Springs, Texas
I have a Ford 6600 with a Bush Hog Front end loader. I am on my second set of front wheels in about 4 years and am guessing that I will replace these in the next year. The failure is hairline cracks in the wheels themselves. The cracks start as hairline cracks at the lugs and work their way outward and inward (to the center hub of the wheel) from there. I cannot say I overuse or even use it a often. The wheels I got at New Holland dealer. I am confident that the lug nuts are tight?Any ideas? Is this common? I think to myself: Cheap/thin steel wheel, worn front end components, wheels were not designed to be used with aloader? Any ideas? Are there better/thicker/heavier wheels offered by someone other than New Holland?
/ Cracking front wheels #3
I ran into a similar front rim problem (another brand).
Was my fault as torque was not good and the rim wobbled loose making oval mount holes.
Because of a-cost and b-rarety I cut a disc that matched the 'disc', welded the 'disc' to the outer rim thereby doubling the center thickness and using the mount holes as a guide drilled out the stud holes.
I then simply used longer mounting bolts to compensate for added thickness.
Have run that way now for about 4 years with no problems at all.
Suggest taking your rims to a good weld shop and having them 'double up' the centers.
Being an off road and slow moving vehicle weight and balance are not issues.
/ Cracking front wheels #4
A couple things to look at are the condition of the lug nuts; especially the taper that pilots the rim. Another would be the toe-in adjustment on the front wheels and condition of the tie ros ends. Excessive toe-out will put a huge load on the rims. The front wheels should have 1/8" to 3/16" of toe-in. Try tightening the lug nuts with a torque wrench.
/ Cracking front wheels #5
I wouldn't use an air ratchet to tighten them either.. those can be good at overtightening and ruining the rim, stud and nut.
In the past, I have welded up some cracks then ground down.. but not for any machines I drive over asphalt .. etc.. only stuf on the farm.
soundguy
/ Cracking front wheels #6
That's that the 1st thing that comes to my mind ??.......
I added all new lug nuts when I changed the wheels. I feel I tightened then sufficiently with a lug wrench. I am trying to find out if what I am experiencing is unique, is the loader to much for factory wheels (Are they cheap wheels?) or is there a front end steering components issue. I am leaning toward the latter as I know I have at least one worn or loose tie rod ends. But it amazes me that this could wipe out wheels.
/ Cracking front wheels #8
I have cracked wheels doing loader work, but the lug nut notion is the most likely if you haven't put a lot of stress on the loader.
/ Cracking front wheels #9
I've had trouble with rims cracking, but only on tractors with side-mount boom mowers. New Holland does make a heavy duty front rim but I believe it's one that mates to a 10.00x16 or 11Lx16 tire. Dan
Partspring original Ford/New Holland parts
/ Cracking front wheels #10
There is one condition that could cause it. There are 2 ways to center a wheel on a hub. One is to use the lug nut holes and the other is to have the inside of the wheel fit tight to a raised rim on the hub. In the second case, the lug nuts just keep the wheel from falling off and thus the holes are often larger. If you put a hug centric wheel on a lug centric hub, the wheels are not correctly supported and they will crack, quickly.
A well informed dealer should know this and not allow the mix up to happen, but good help is hard to find...
jb
/ Cracking front wheels #11
Sounds like you got some bad wheels,two times in a row from same manufactor.[if first set was bad,why wouldn't second set be bad]
Went through two fuel pumps for my oil furnace in one week,just recently,[think I finely got a good one],,who knows,metal was to hard,holes weren't rimmed/beburred right,no quality control,combination?
Would any deere,kabota,kioti,mahindra wheels work,maybe another brand would be better,maybe they would come from different manufactor?maybe that wheel place just had a bad month,maybe third set will be the charm?
/ Cracking front wheels #12
I think John Bud is right on. If the hub is oversize or an incorrect application the wheel won't sit flush on the hub and the lug nuts will place a constant stress on the wheel leading to cracks.
Check to make sure that the wheel seats with full contact on the hub. You should see evidence that the hub is clean from the contact.
If the wheels seat with full contact on the hub then the wheel design is probably just too weak for the application.
/ Cracking front wheels #13
tire pressure to high or lugs may be to tight. let us know what exactly it is when you find out.
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
Welcome to the Ranch Metal Decorative Sign (A64557)
Welcome to the...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
2011 Ford F-150 Pickup Truck (A66736)
2011 Ford F-150...
2017 Ford Escape SUV. (A66738)
2017 Ford Escape...
